unconfigure ssl certificate
unconfigure ssl certificate [trusted-ca | ocsp-signature-ca] [file_name | all ]
Description
Removes a trusted CA certificate or OCSP response signature CA certificate from the switch.
Syntax Description
trusted-ca
Specifies trusted CA certificates.
Removes the CA certificate file(s) from folder/config/ssl/trusted_ca_certs/.
ocsp-signature-ca
Specifies OCSP signature CA certificates.
Removes the signature CA file(s) from folder /config/ssl/signature_ca_certs/.
file_name Specifies a single CA certificate file for removal.
all Specifies all CA certificate files for removal.
Default
None.
The following example removes all trusted CA certificates from the switch:
unconfigure ssl certificate trusted-ca all
This command was first available in ExtremeXOS 22.1.
Platform Availability
